Well, I made an offer and it was accepted, I’m picking the boat up Sunday.
The keel needs to come out and the trailer needs work. Being a woodworker gives me a great toolset for building cribs.
Keel will be loosed, the boat will come up, and the keel will be rolled away with the trailer.
I have a method for plucking it up off the trailer and raising it off the ground, and that method is greatly helped by having the cribs placed further apart. It also seems like a more stable setup, which is important because of all the work I’ll be doing down there. Two more stabilizing supports will be added on either side of the keel, after the trailer is pulled away. But for a few minutes, the full keel-less weight (1475lb?) of the boat will be supported as pictured.
The hull contact points will be over a square ft, plus contoured and padded to prevent pressure points. There will be 2 at the bow, 2 at the stern (the 2 amidships won't be in place yet). Is the hull ok to take a load like this? Are there any hull points where one should not attempt to support the vessel?
Thanks again!
Thanks again!
