i am considering mounting a anchor assist devise
May 3, 2022
5
hunter 34 craig
on my hunter 34 i have noticed there is a void between the top of the deck and the inside overhead about 1/2 inch so any ideas on other windlass anchor winch installs that and there is a considerable distance from battery 0 cable is pretty expensive install battery closer to winch ?
any pointers appreciated
Mar 20, 2015
3,305
C&C 30 Mk1 Canada
Holy Hanna was that hard to read.
I assume you are referring to how modern, mass produced,boats are commonly made Vs a structural defect in the deck coring or fiberglass layup.
Windlass mounting:
-Cut a hole in the overhead
-install the windlass to the deck, with a substantial backing plate
-make an attractive, removable, panel that covers the backing plate.
You will likely notice that your boat already has factory installed,removable panels, where other deck hardware is mounted.
(Photos of the mounting location would help people assist you)
Windlass power cables:
If you install the existing batteries closer to the winch, you would then need to extend the other wiring (with larger gauge) to the new location. No real cost+time benefit there.
If you add batteries forward, just for the windlass.. you would likely use a second dc charger with smaller cables feeding it. (In that case you had better hope you don't use the windlass too much over a short time, otherwise the charger can't keep up)
3 options for the cable size...
1) get a 24 volt windlass and set your boat up to use both 12 and 24 volt circuits. (24 volt circuits can use smaller gauge wire)
2) spend the money for the 12 volt large gauge wire..it's a boat and they aren't cheap.
3) use a manual windlass
Personally I would use option 2. Installing a 12V windlass with a long cable run is likely to be the cheapest, simplest, and lightest solution unless you want to do it manually.
5
hunter 34 craig
thank you ward H i appreciate your quick reply and spending the effort to correctly decipher my lousy nonexistent punctuation
i am sorry it took me to long to reply i am working a fultime job and living on one of my sailboats and working at cleaning bottom of other sailboat and waiting for painting weather i am in alaska i hope i dont have to wait all winter to paint
thank you sincerely
R Nelson
hunter 34
newport 30
