Go for it!
Hello Roy, Yes, we are happy with our Beneteau 373. The main issue has to do with commissioning, make sure the dealer goes over the whole boat thoroughly with you. When the boat is launched pay attention to how she sits on her marks ( check that the boot stripe is parallel to the water), if not, get the dealer to add some ballast to the bow. This will help when sailing in to the wind and also make it a little more manageable in close quarters. The big three blade prop tends to cause cavitation around the rudder which will make the boat round up in to the wind under full sail as the winds approach 20 knots so make sure that you reef early. We have sailed in 35 knots and 12-15 foot waves on the great lakes without too much trauma. One thing that did let us down was the refrigeration unit. We had to get a replacement control unit with a higher start voltage, get the dealer to check that you have the upgraded control module. Make sure the dealer checks all hose clamps and through hull fittings, and also the cable tension and quadrant clamp on the steering mechanism. Also, have some one go over all of the gel coat, particularly on the deck and around the transom, it is after all a production boat and it will be easier to get them to fix things before you sign it off. We have spent the past two summers cruising the North channel ( Northern lake Huron / Georgian Bay) and thoroughly enjoyed the boat. We plan on taking her South and in to the Bahamas next fall. Regarding the anchor, we rarely tie up at a dock and spend most nights at anchor. We have a 20Kg Bruce with 200 feet of chain and this combination has yet to let us down. If you plan on cruising get plenty of good sturdy ground tackle. Where will you be sailing?I have tried to include a movie sailing at 15-20 knots. as you can see..no problem! Regards......................Tony.----- Original Message ----From: "twofoot2@verizon.net" To: tsellick@rogers.comSent: Tuesday, November 20, 2007 8:27:33 PMSubject: Email from a Hunter ownerThis email has been generated from the HunterOwners.com at http://www.hunterowners.com. Your email address has not been displayed to the sender. Sender: Charles at twofoot2@verizon.netHello Mr. Sellick,I am going to purchase a new 373 Beneteau for 145,000. ((Dealer wont include the anchor package)) The boat looks beautiful, wife loves it. I have heard comments that the boat does not sail well. Could you please forward your opinion of your boat? Are you satisfied? I appreciate any and all information. I am going to contract the day after Thanksgiving.Many many thanksCharles
