hydrolift muffler leak
john Fasulo
I have a 1984 C30 The hydrolift muffler leaks around the muffler connection to the engine.. any ideas on how to fix? (or replace)
Take the hose off
and inspect the fiberglass nipple on the muffler. If necessary, build it up with fiberglass or marine tex and use non-hardening pipe dope (Rextor) on the fitting. Consider buying a hump hose from Catalina if your connecting hose is the stiff black material. The hump hose imparts less vibration. Check the C30 association website, too.
