Hydro for CNG tank
Oct 26, 2010
2,168
Hunter 40.5 Beaufort, SC
I can't get a scuba shop to agree to hydro my CNG tank. I have found a welding gas supply place that ships their tanks to Jacksonville FL for hydro but they need (or want) a "code" to put on the paperwork before shipping and hydro and can't seem to find the right one. They deal in all kinds of gases including a lot of welding gases but I'm in limbo trying to figure out what code they need to use.
Has anyone had their thank hydro'd and if so either how did you convince a scuba place to hydro it or what code did they use at whatever other place who did your hydro use? I'd sure appreciate the help in getting past this hurdle. By the way, the top valve can be removed and thus the tank is open and I could use some air to make sure there is no residual gas in the thank. Without the "Compressed Natural Gas" sticker on the top of the tank what is the difference between a scuba tank and a CNG tank? I know the valve at the top of the tank is different since the CNG tank valve threads are left handed but is the tank itself different?
dLj
Mar 23, 2017
4,640
Never mind- I thought I had it - still looking...
dj
dLj
Mar 23, 2017
4,640
OK - several sources now tell me the same thing - "CNG tanks cannot be recertified after they reach their expiration date, so they must be replaced. "
I was originally directing you to 49 CFR 571.304 - Standard No. 304 Compressed natural gas fuel container integrity. But then I was reading that standard and realized it is pretty much only for initial certification...
dj
Likes: LloydB
Oct 26, 2010
2,168
@dLj I believe that the "expiration date" issue applies to non-steel type tanks that are commonly used in CNG vehicles. CNG tanks like we usually have in boats are heavy walled steel tanks rated at 2000 psi to 2200 psi, not the 3000 or 3600 psi large tanks used in Vehicle applications. Any references to the "several sources" would be appreciated. Thanks
JamesG161
Feb 14, 2014
7,912
Hunter 430 Waveland, MS
Depends on the material of construction of the your CNG tank.
Compressed Air or Scuba has moisture with the air
CNG not much moisture.
Scuba moved to Aluminum tanks for this reason
Try asking the local Propane suppliers.
Jim...
dLj
Mar 23, 2017
4,640
The first reference would be:
However, if you read the standard I did post - that standard applies to all materials including steel and aluminum tanks.
dj
Likes: JamesG161
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
Following. I tried all over CT to get my 5# propane tank from '99. i could change the valve to current but no one to test and stamp. New alum tank is >$300. steel tank is $53 on Amazon. The original tank is in pristine condition.
Likes: JamesG161
Jun 11, 2004
1,829
Oday 31 Redondo Beach
Have they said or given you an example or type of "code" they are looking for?
What kind of cylinder is it, e.g. DOT 3AA 2250? That's the ubiquitous cylinder used around here for marine CNG stoves. The type should be plainly stamped on the neck area. That's a common scuba cylinder and I believe there is no specified end of life. It just needs to pass hydrostatic testing.
The scuba shop that does my hydros just asks me to make sure it is completely empty. Since, as you mentioned, the valves are different, they take off my valve and use their own for the test. Have you tried asking the scuba shop if you brought in your cylinder without the valve can they put on their own valve to do the test?
My cylinders are from 1978 (yes, 45 years old) and no one has said they are too old. I used to take them to an industrial gas place (since out of business) and a guy there said they were in great shape. He attributed that to the fact that they have been cycled a comparatively very few times compared to "working" cylinders and that its the number of cycles that really count.
Likes: JamesG161
Oct 26, 2010
2,168
Thanks for all the responses. I believe I have resolved the issues. The shops that I took the tank to (one industrial gas and two scuba shops) all send their tanks out to third parties for hydro and I think it is that fact that was causing the angst in accepting them for hydro. The scuba shop suggested I call a marine supply shop that performs their own hydro's rather than shipping them to a third party.
@Richard19068 the tank is a DOT 3AA2400 steel tank and in good condition and is, as you said, just a scuba tank with a different valve. The shop (River Supply, in Thunderbolt GA) just said to remove the valve, put in a plastic plug to keep the moisture and air out (which they supplied) and they would do the inspection and hydro. If this works out, I have three more tanks to take to them and get them certified.
Likes: JamesG161
Oct 26, 2010
2,168
So one lesson her for consideration is if you are looking for a CNG tank you can buy a good used DOT3A or DOT3AA steel tank with the correct neck size (some old tanks have smaller diameter necks so be careful it will fit your valve) and install the proper valve for a CNG application. Not sure where you would find those valves but the tank is just a steel scuba tank. Don't get the 3000 psi or above tanks because your regulator will probably not work for that higher pressure (but that is just an assumption)
Dec 25, 2000
5,948
Not so. In Seattle Fire King hydro re-certifies tanks including CNG steel tanks, which have no expiration date as long as they have no deep corrosion pits or damage according to their statement. My tanks have been re-certified many times by the appearance of previous date stamps.
dLj
Mar 23, 2017
4,640
Gotta say - I love being wrong on that one... seriously...
But you are actually quoting a quote I took from a document which I referenced.
dj
Dec 28, 2015
1,920
49 CFR 180.205 (j) Cylinder Condemnation....Take a look at it. It matters what the cylinders actually categorizes as regarding life span. Steel doesn't have a "drop dead" life span like composites and alloys that fail out with inspection and hydros.
dLj
Mar 23, 2017
4,640
Yes, dj. Knew that going in. Anecdotal, eh?
Hmmm...
Anecdotal: (of an account) not necessarily true or reliable, because based on personal accounts rather than facts or research.
Not sure that's the correct term as I based it on a CNG standard for fuel tanks and provided facts from what looked like a reliable source.
Now, without knowing what exact standard (the original question), it was an attempt to aid in the search. Take it for what it's worth.
But I must ask - since you've done this numerous times - what was the standard you had your tank recertified to? Now that might make for a far better addition to the original question.
dj
Dec 25, 2000
5,948
The only re-certification standard that was referenced was 2,250 pounds max pressure, good for five years.
Jun 11, 2004
1,829
dj
The general standard for DOT 3AA cylinders is that they are tested at 5/3rds of the rated service pressure. There are obviously other steps in the procedure but my assumption (yes, I know, there is that word again) is that the facilities that do the testing meet the requirements of the various sections of this CFR:
  1. Title 49
  2. Subtitle B
  3. Chapter I
  4. Subchapter C
  5. Part 180
PART 180—CONTINUING QUALIFICATION AND MAINTENANCE OF PACKAGINGS
180.209 Requirements for requalification of specification cylinders.
(a) Periodic qualification of cylinders. Each specification cylinder that becomes due for periodic requalification, as specified in the following table, must be requalified and marked in conformance with the requirements of this subpart. Requalification records must be maintained in accordance with § 180.215. Table 1 follows:
Table 1 to Paragraph (a)—Requalification of Cylinders1
Specification under which cylinder was madeMinimum test pressure
(psig)2
Requalification period
(years)
33000 psig5.
3A, 3AA5/3 times service pressure, except non-corrosive service (see § 180.209(g))5, 10, or 12 (see § 180.209(b), (f), (h), and (j)).
Oct 26, 2010
2,168
Just posted another thread but River Marine Services didn't reject the tank but they wouldn't test it either as they said they didn't know the "cleanliness spec" necessary for a CNG tank as opposed to some other tank like an Oxygen tank or a SCUBA tank, so they declined to hydro it. They mostly hydro SCUBA tanks and air tanks for inflating emergency rafts. I never imagined it would be this hard to get this done.
@Terry Cox I'll try and call Fire King of Seattle and see if I can pick their brain on how to get somebody here to do the hydro. This is really frustrating.
