Patrick
My foller furling, Hood 800 single line, wont work. With the sail rolled up, pull on the sheet, either side, the sail comes out without a problem,and if the wind is up it actually flies out.The problem arises whem I'm done sailing and attempt to roll the sail in.The drum wont turn and I am forced to go to the bow and then turn the sail by hand one or two turns and then the sail can be rolled up by pulling on the roller sheet.I have the drum currently off the boat and it turns freely, not hint of bad bearing.Anyone have an identical problem ?
