Low RPM Vibrations
Your onsite mechanic is probably right, but...I've seen several threads on this site about 3GM's and vibration at lower rpm's, my H34 rattles a bit in gear around 800 rpm and that's with a fairly new cutlass bearing and a 3 blade campell prop. However I would not describe what my boat does at lower RPM's as a "very loud vibration".Years ago in an earlier boat I cranked her up one morning and all hell broke loose, I thought she was going to shake apart. It turned out to be a small colony of barnacles making their home on only one propeller blade. So a quick dip in the water is worth doing.If the boat is fairly new to you, go back to your surveyor for suggestions and input. My biggest question would be, "Is this something that I can address at my next haulout or does it need immediate attention?" Yanmar recommends a 15x15 two blade, but hunter used 15x12's on alot of the earlier models, my 1984 included. But that shouldn't be a problem unless your fighting a strong headwind or current.Let us know how this turns out.
