hunter31 cabin sole
terry holt
I am about to pull out the settees and replace a large portion of the cabin sole. I have a piece of marine grade plywood, a 1/2 inch thick, and need a piece of teak and holly laminate that matches the old stuff. Is this even possible? I am sure others have had to replace this stuff, if anyone knows a vendor for the laminate, I would be very appreciative.
Dec 2, 1999
15,184
Not going to happen.
Terry: That match is not going to happen. The main salon is your biggest problem. I would suggest that you get some stuff to do that section of the salon. (see Rick Dinon's new floor in the photo forum link posted below). The grate under the companion way can stay. It may need refinishing but that is no big deal. This is what we did in the galley area. Much more durable than the original cabin sole. The old before photo is messed up but you can see the finished product ( http://www.sailboatowners.com/upload/display.tpl?folder=Dion73061279998&fno=17 ) This only leaves a couple of other sections that you should be able to handle without too much ado. I would be interested in your final product.
