Hunter tank monitor
May 21, 2014
128
Hunter H44 Toronto
Our 2005 tank monitor is failing to read properly from one water tank. Now I’m not confident of readings from the holding tank. Any suggestions other than a replacement monitor? Thanks
Dec 2, 1997
8,993
- - LIttle Rock
Replace it. The tank monitor that Hunter installed is obsolete, plus it never worked very well on a lot of Hunters because the guys who installed 'em didn't follow the installation instructions.
SCAD tank monitors Scad Tank Monitors are top rated, not expensive and available from a number of retailers including Amazon. It also uses sensors that go on the outside of the tank. You should be able to use the existing wiring, which will make replacement a fairly easy job.
--Peggie
Likes: wyctoronto
