Hello. Looking for thoughts on thrusters for the Passage 420. With a full enclosure on a high center cockpit, windage docking is substantially. Traditional bow thruster not viable with forward head liner. Intrigued by jet thrusters that utilize a central pump and only require plumbing and the jet outlets. The system built by Holland Marine draws over 700 amps, which is a lot of draw down on the batteries. That and the videos showing mediocre thrust leaves us wondering if a more robust system could be AC run off the generator.
