Hunter Passage 420 question
Jfg
Oct 19, 2019
2
Hunter Passage 420 Montreal
I have a Hunter passage 420 2004 .I have a question about the generator it stops after 30 to 40 minutes I changed everything filters, pump impaler, the streamer is clean. When it stops the engin is not hot and the exause pipe. I don't know what to do. I if I put the generator at on or off the engins stops anyway. I don't have any gage and it as 900 hours. Its a OM673L3. When a use the generator on the control panel Anxantrex do I need To do something the the battery?
Dec 25, 2000
5,953
Our Onan 8kw genset has three sensors, each able to shut down the engine. High coolant temp, high exhaust temp, low oil pressure. Ours has a breaker that trips that must be reset on the control panel. A few things to check:
1. Even though the sea water strainer is clean, are you getting good water flow out the exhaust discharge port? An improper placed strainer cover will suck air, preventing insufficient coolant water flow.
2. What micron is your fuel filter? Ten should be fine. Our original was two, which is too fine.
3. Are you getting good fuel flow from the engine side of the fuel filter? A restricted flow will cause the engine to shut down.
4. Any intake air flow blockage, such as an air flow filter?
5. You may need to connect an oil pressure gauge to verify oil pressure.
Diesel engines only need air and fuel to run, but other factors may cause it to shut down. Ours shut down twice before: a clogged seawater strainer and a clogged fuel filter.
The Xantrex charger/inverter or battery bank should not affect the genset from running. I’m assuming that the genset is generating 120/130 volts ac when running?
Please let us know if you find anything.
Likes: LloydB
Jfg
Oct 19, 2019
2
The air filter was very dirty ( probably never change) the sea water arrived fine to the pump.
Dec 25, 2000
5,953
Yes, but are you getting a good sea water discharge out the exhaust port? A number of things between the pump and the exhaust port can restrict coolant water through the system.
