Hunter Passage 42 water tank
1
Hunter 42 Passage Coronado CA
Anybody have the dimensions of the original forward water tank? It holds 75 gal. It's aluminum. Have to replace it.
Oct 10, 2009
28
Catalina 34 Ladysmith
Douglas, I do not, but I am sure another P42 owner will.
Again, we as owners, do not have documentation and it totally amazes me still that Hunter cannot provide an online manual for our boats, but can for I think every other model.
Just venting.
KD3PC
1,069
boatless rainbow Callao, VA
Phil and G.Morris
just checked that archive and both water tank drawings are there, and they look to match what I had on my 1991. The aft dimension on the vberth tank matches what I measured, and the shape is what I expect.
thanks for the post
Jul 25, 2004
359
Hunter 42 currently in New Zealand
P42 forward water tank replacement
I need to replace the forward water tank on my P42 as well. Any ideas on how to get one inside the boat? The flexible ones on the market that fit inside that space just don't have enough capacity to make it worth it.
I can easily cut up the old one to remove it, but how do you get a new one inside the boat??????
Cheers,
Paul
Rick D
Jun 14, 2008
7,182
Hey, Paul...
Cheers,
Paul
Excuse me for butting in here, but could you have two made which together would fit in the bad tank's space? I had to do that for a holding tank for a previous boat, although the siamesing of the tanks could have been problematic. Wasn't though. I would think twin water tanks would be a possible solution.
Jul 25, 2004
359
Rick,
Thanks for the idea! I never would have thought of that, and it opens a lot more possibilities to work with.
Cheers,
Paul
