Furlers, etc. no top priority on 16-yr old vessel
On a 16-yr old 45-footer I would look first at construction and condition of hull, keel, rudder, mast & compression post, stemplate/chainplate areas, plus how watertight the decks are and what the condition of the engine is. If there are major problems in any of these areas; who cares what brand furler and other deck hardware is mounted?! From personal experience I know that it is feasible to get a new Hunter 43 ready for serious offshore cruising in tropical latitudes (plus coastal cruising in subtropical and temperate zones) with a wad of boat $$ and quite a bit of sweat equity thrown in. Not quite enough to make me consider a Pacific Seacraft, Yaga, Tartan or Sabre as economically equivalent choices (let alone the overpriced "super-brands" ), but certainly enough to make me think twice about trying to whip an older large Hunter into seaworthy condition (or - for that matter - some of the newer Hunters without toerails, anchor lockers, tie-rods or believable seabunks). Not that it cannot be done, especially if the quality of your sweat equity is worth far more than mine, but it would tend to faze me unless I were fully retired and got more fun out of working on my boat than sailing it.When we were looking for a vessel in 1991 (and ended up buying our Hunter 43 "Rivendel II" in California) there happened to be 2 used Hunter 45's dry-berthed at Tidewater Marine in Havre de Grace (Maryland)where we had been sailing Bob Buchanan's Hunter Legend 31.5 "Windtryst" for 2 summers. Both 45 keels showed a clear crack marking the keel-hull joint, whereas one of them also had some cracks in the fiberglass oilpan area under the diesel engine. Perhaps, these problems were cosmetic or directly traceable to some type of mishap. Whatever the cause, it did cool my enthusiasm for what appeared to be otherwise a nice design. A final consideration to keep in mind is that towards the end of the 80s public appreciation for larger Hunters appeared to be at an all-time low, after a string of rudder failures, oil canning complaints and other structural question marks. In response, Hunter appears to have made a major effort to redesign its larger vessels which resulted in the "classic" Passage 42, and its aft-cockpit Legend 43 cousin. On the coat-tails of the Passage 42, with its amazing used-market value, the old Hunters 45 began a slow climb back. If my memory serves me well, in 1991 several Hunter 45's (only 5 years old or so) were on the market for under 100 k$. Some five years later the same vessels were selling for well above 100 k$!Good luck!Flying Dutchman
