Hunter Hull Number location HELP PLEASE
14
2 Passage Panama
I found the one on the outside of the hull on the starboard aft side. It is partially covered with a plate and bolts holding my ss davit system.. I know there is a second hull number stamped somewhere else. I have seen it but do not remember where. I am 3000 miles from my boat now and need a friend to photograph the hull number. Could someone please direct me to the second hull number on my 1996 Hunter Passage 42. Thanks very much
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
What about a copy of your coast guard documentation certificate that should be in your navigation table on boat or second copy kept on board in a small hidden water proof safe?
Will this help? For insurance purposes right?
I believe if memory serves me I have seen the hull number on my 356 in various other locations as well. Try checking both port and starboard sides of hull, also try below deck. Say engine area,inside lazarrette storage areas, and behind instrument breaker panel at nav.
Good luck...
Feb 1, 2009
14
2 Passage Panama
Good luck...
Panama registered boat and the reason I need this is to re-register in USA. They want it photographed and since I am not near the boat I have to have someone do it. It seems I have seen it stamped in the propane locker starboard aft. Does that ring any bells?
Thanks for your help
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
Check with the factory or a dealer for the location.
