My personal perspective (long)
I had a 1999 H310, which I traded in this past autumn on a 2005 H36. I don't know if my situation has sufficient parallels to yours to make my comments of any value, but here goes.I wanted a new boat, and thought I'd learned enough about things to fix or upgrade to make the risk of buying anything but a fully-equipped and well-proven used boat worth taking.I finally settled on the H36 after looking at a lot of alternatives because it is the best compromise between all the things I consider important for the price. I'm a short- (often single-) handed coastal North Atlantic cruiser. I'm not a floating condominium owner, a trailer sailor nor an ocean crosser. My idea of a passage is (mostly) in sight of land or only a little farther out where I can navigate by radar images of the coast (plus GPS and chart-plotter, plus GPS and Maptech software, plus paper charts).In my opinion, Hunters are analogous to Fords, not BMW's or Mercedes; specifically, I consider them analogous to performance-equipped Mustangs.Enough of them have been produced, at sufficiently high volumes over enough years, to have generated the (possibly apocryphal) stories about quality analogous to the "beer-can-found-behind-the-door-panel" tales; the kinds of occurrances that would'nt be a threat to life or limb, just an annoying shaker of one's faith in the product's perfection.They do exhibit pretty good performance for the buck, and have a high fun quotient. They're not Ferrari's, but they aren't SUVs, either.My H310 had some corners cut that I found appalling - like no seals or latches on cockpit lockers, and no coachroof grab rails. I addressed both issues and was glad I had when broached by a quartering sea that was breaking higher than my bimini top when crossing the Merrimac River entrance bar at full ebb after Hurricane Jeanne (with an anxious USCG 47-footer shadowing us in). I was even more glad, however, to not be in a "safe" traditional long-keel, blue water design which would have been rolled - while my litle H310 just skidded sideways away from the wave until the wave's height when it finally boarded my cockpit was only waist high.I've had the little H310 out in sufficient coastal Atlantic nastiness to trust her. I'd hate to find myself in "the perfect storm" with her, but don't go out without checking the weather.The H36 has met the letter of the law on the Category A classification requiremnents (such as seals and latches on locker lids), but it is not specifically designed for ocean crossings. The South African dealer's Hunters are deliverd on their own hulls from FLA, however, and I doubt the delivery captains would risk that in anything that couldn't stand-up in heavy weather on blue water.The H36's construction includes hull-flange-to-deck bolts every 6 inches, with toe-rail-to-deck fasteners between each pair of said bolts. That's a lot of support for the 3M 5200 seal. When combined with the Kevlar reinforcing layer in the forward section, that gives me confidence that I have plenty of hull strength if I do get caught in heavy weather, and if I cut away any spars before they hit the hull too many times in case of a dismasting. (I also find the 3-point-staying of the B&R rig plus the mast support struts confidence-inspiring.)Obviously, I can make no estimate of how many years of heavy weather hull-flexing it'd withstand before fatigue set in, and (like most boats) it doesn't have any water-tight bulkheads.However, if I didn't cover those big "windshield" deadlights with my nested dinghy, I'd sure want (solid) storm covers for them to not test the acryllic (and seals) with a ton of wave. (If you want maximum strength against such "blunt trauma," you use acryllic. If you want bullet-proofing against stress-concentrating penetraters, you use Lexan. Both will test their mountings when their area picks up more load than their perimeter can hold.)More importantly, the very reasons I love the basic design's performance - both in keeping up with much large boats under sail, and reacting to beam-on waves - are the reasons it is a tiring boat to have to steer for long periods in heavy weather. It turns on a dime, whether from helm input or wave action. When that's what you want (most all the time, for me) it's "responsiveness." When you'd like to let the autopilot steer and take a break in very heavy conditions, it's "skittishness." A heavy-duty, hydraulic below-decks autopilot wouild address that problem, but only with a load of batteries I don't care to carry. A "blue water boat," like a Pacific Seacraft, would not have to address it. On the other hand, the Hunter's light-air acceleration makes the Volvo-like Pacific Seacraft look pretty stodgy - to say nothing of a sluggish minivan-like Island Packet.Of course, for the price I paid for a new H36, the only new Pacific Seacraft I could have bought is a lovely (LITTLE) Crealock 31.There are no perfect boats, but the Hunters are good enough for the purposes of enough people that you don't see Luhrs Marine starved for customers - many repeat.Good luck with your decision.
