Hunter 50 prop nut, key and ping
Oct 28, 2021
19
Hunter 50 AC Naples
Hello.
Since 3 years I'm the new and happy owner of a 2007 Hunter 50.
The boat has an Autoprop as propeller and the oroginal fixed 3-blades is stored in a locker but can't find the bold, key and pin needed for the replacement (emergency and just in case)
Could someone help where to source the appropriate prop nut, key and pin (shaft is 1.1/2 inches)
Thank and warmest regards,
G
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Any prop repair facility will not only be able to tell you what you need, but sell it to you as well.
