Hunter 50 - brand and model of refrigerator
Oct 28, 2021
19
Hunter 50 AC Naples
Hello.
Does anyone knows brand and model of the refrigerator installed on H49/50 in year 2007?
I've an H50 AC 2007 and time to change the refrigerator so I'd like to understand the dimensions to look on the market and before removing the currently installed.
Thanks and warmest regards,
G
Hunter 49 60803 Lake Erie
62IXD4-F-1
Sea Steel C62IXD4-F Refrigerator / Freezer, 2.2 cubic ft.
C130RXD4-F
Sea Steel C130RXD4-F Refrigerator / Freezer (External Cooling Unit), 4.7 cubic ft.
I have a 2007 Hunter 49 and replaced both mine 2 years ago. I don't remember the measurements of the old ones but I replaced them with the two listed above. I bought them at Citimarine.com they are manufactured be Vitrifrigo. I had to do some minor wood trimming to get them in but they pretty much slid right into place. You can get their measurements on Citimarine.com. The good news is they are set up with recharging ports so they should last me longer then the old ones which were sealed and FYI the wife loves them.... so that is a plus.
If you have the time (which I didn't as we were shoving off for 3 months when I installed mine) you can special order them with out the little freezer section built in (Citimarine only stocks the ones with the built in freezers) which gives you more frig space.
Likes: ScottySailor
Boiler
Feb 15, 2022
33
Hunter 49 Houston Texas
I am in the process of replacing the large upright refrigerator. The one in it is a Vitifrigo 118 liter (4.2 cuft) and I am going to replace it with a Dometic 115 liter (4.1 cuft). The dimensions I saw on the fridges in this class will fit the opening. There needs to be a 2 inch air gap on the top to allow for proper air flow, which is the reason I went with the 115 vs something like a 130 liter (4.6 cuft).
Jun 17, 2022
278
Hunter 380 Comox BC
Different hulls could have had different accessories installed ... best to remove what you have and check the opening size.
Likes: Hello Below
