here it is
After three trials to set the Maxprop to provide 3,100 rpm WOT. My runs provided the following results in flat water with no tide and 4 knots wind, All measurements are SOG per the GPS. My sailing results are pretty much like everyone else.1,400 RPM= 5.4 knots1,800 RPM = 6.6 knots2,200 RPM = 7.3 knots2,600 RPM = 7.8 knots2,800 RPM = 7.9 knots3,000 RPM = 8.1 knotsThis is on a 2006 H44AC with full fuel tank, 3/4 full starboard water, empty port water. This is a stock boat except the 230 lb. Genset and 90 lb. A/C.One other note. This fall, on my top off, I added Diesel Kleene PS to the tank using the ratio that basically incrased my Cetane 3 points and adds lubricity. It may be my imagination but it appears to run smoother and have more power. I've read that typical marine diesel at the docks has a lowered Cetane level for financial or storage reasons I am not sure. Either way it's running great and with the Cetane boost and Maxprop I am quite happy with the speed.
