Hi Peter, we have a fixed three blade...
on our 1991 P42 with a 57 HP turbo Yanmar and a 1 and 1/4 inch prop shaft. When I cruise with the engine I normally keep it at 1,800 to 2,000 RPM which pushes the boat at seven to eight knots. The 4JH2TE in our boat has a rated maximum of 4,250 RPM without and around 3,800 under load. Some will say our cruisng RPM is too low. They will claim the lower RPM will glaze the cylinder walls, carbon desposits will build up and all sorts of horrible things will happen.As long as the engine reaches its normal operating temperature, none of these things should happen according to my diesel engine sources.Whether you have a two or three blade prop your engine should be able to push your boat to hull speed, I'm guessing between six and seven knots. If you try a higher RPM, say 3,000, that might get you to hull speed.Terry
