Clarifications for Fred and Gerry
Sometimes, when I make a text correction in one of my HOW posts part of the title mysteriously disappears. Don't know if this is Phil's problem or something with my own computer set-up.At any rate, the lack of specific information provided by Gerry prompted my half-hearted attempt at humor. For that I want to apologize to him. Fortunately, Gerry's second post provides a tad more information.Gerry, the placement of a generator under the foreward bunk sounds rather odd and undesirable to me in light of the potential noise, fume and heat problems. This is not to say, of course, that an installation there could not be done properly. However, that might require quite a bit of engineering, including extra heat and sound insulation, ventilation and diverting the exhaust gases to a drier spot on the hull.And, yes, the extra weight could be undesirable in the bow, particularly if it weighed a lot and were mounted off to one side.What are type (diesel or gasoline), brand and model of that generator? This information should enable you to find the weight, e.g. by using Google on the internet. Also, it would be important to find out how and where the exhaust hoses are connected, whether it has air or water cooling, how old it is, when it was last used, whether it worked fine, etc., etc.Nonetheless, if you do like the boat you should certainly not let the deal fall through because of the generator placement alone, even though it might take a fair amount of time, money and elbow grease to make thigs right in that location (or to move it somewhere else). Finally, you might decide you don't need a generator and put it up for sale on Ebay...... On "Rivendel II", our Legend 43, we have sailed all over the Pacific for 13 years without ever feeling the need for a generator! Success,Flying Dutchman
