Hunter 41ds septic sensor length
Mar 16, 2021
93
hunter 41 DS tacoma
I’m headed up to Fisheries Supply & forgot to measure my septic tank depth. I aim to buy a stick-on system. Anybody know sensor length?
Oct 26, 2010
2,234
Hunter 40.5 Beaufort, SC
Not sure of the brand you wish to buy/install. The external tank monitor that I installed had two foil strips that are placed about 3 inches apart on an external side of the tank. There is a cube with wires that connects to the foil strips and provides the signal to the display. The foil strips are cut to length and there was way more length than I needed for my installation. Once installed and powered up you calibrate the instrument to read empty and full. I would guess than most external sensor types are similar.
Likes: Nachismo
They are due to get some in soon. They are on back order.
