Hunter 410 Refrigeration amperage
Hunter 410 Grand Rivers, Kentucky
Does anyone know the max amperage draw for a 2002 Hunter 410 refrigerator/freezer?
Sep 11, 2011
428
Hunter 41AC Bayfield WI, Lake Superior
My 2004 AC41 has the fridge at about 2.5 and the freezer at ABOUT 4.5. My manuals are 250 miles away, so I can not be more precise.
Check the web site for your brand and I bet that the details are posted.
Jun 6, 2006
6,990
My 40.5 reefer and freezer both run at 5 amps. They both havean air cooled condenser. Run time varies with temp. Above 90 degrees it runs 90% of the time, at 60 degrees it cycles at 50%
Tantor
Dec 25, 2010
85
Hunter 410 LaSalle, Mi
Here is copy from my manual:
POLAR Mate Specification - Dometic / L-Rev 20140404 /2001
Specification Measure DC Air-cooled(1) DC Air/Water(2) AC Air/Water (2)
Capacity .......................................... Btu/hr ........433 .................. 538 ...........................582
Power Consumption .........................Watt ........ 65.4 .................... 68.5 ......................... 212.8
Current Consumption (12VDC) .......Amp. ........ 5.45 .................. 5.71 .................... 1.85@115V
Current Consumption (24VDC) .......Amp. ......... 2.7 ..................... 2.9 ........................... N/A
Sound power level at one meter ......dB(A) ..........30 ...................... 30 .............................35
Displacement cu.in.(cc.) ................ 0.15 (2.5)
(1) compressor & fan
(2) compressor, fan & pump
Technical Data
Evaporating temperature: .............. -22°F to 23°F (-30°C to 5°C)
Refrigerant R-134A charge: ........... 6.0 oz. (113.4g) Polar Mate Air Cooled 12/24VDC
6.5 oz. (141.7g) Polar Mate Air/Water Cooled 12/24VDC
8.0 oz. (226.8g)Polor Mate Air/Water Cooled 115 VAC
0.5 oz. (14.2g) Polar Evap (U-shaped evaporator plates)
0.5 oz. (14.2g) Evap I (small 4-sided evaporator plate)
0.5 oz. (14.2g) Evap II (large 4-sided evaporator plate)
See data plate for charge on custom plates.
Note: Add Polar Mate charge plus evaporator plate charge for total system charge.
Refrigerant metering device: ......... capillary tube 0.025" x 10.8' (0.63 x 3550 mm)
Voltage range: ............................... 12VDC: 10.4-17.0
24VDC: 22.8-31.5
115VAC: Do not operate below 100VAC
Condensing temperature: .............. Max. 140°F (6°C) at stable conditions
Max. 158°F (70°C) at peak load
Ratings Condition
Air/Water Cooled Air Cooled
Evaporating temperature ............... 20°F (-6.7°C) ............................... 20°F (-6.7°C)
Condensing temperature ............... 100°F (37.8°C) ............................ 120°F (48.9°C)
Jul 28, 2012
79
Hunter 410 San Blas,Mexico
On my 410 with a water refrigeration unit and an extra cooling fan, I consistently draw 6 amps. On start up it may jump as high as 12.
