Starter
TimIt's not your engine, it's the starter and the wiring to it. Feel good, you're not the first to have this happen.First, check all the connections.Make sure you check the system ground wire, too.Second, read your manual or trace your wiring, you could very well have "undersized" wiring and you may have to simply up-size the wiring.You should get very familiar with the wiring from your start and ignition switches, as well as your batteries, and learn as much as you can so you can begin to understand how it works and decide what's best for your particular situation. Start with making a drawing of it, which will help you understand the components and connections, unless you already have one in your owner's manual.Unless someone here has specific input regrading Tim's specific boat, I really can't add much more: connections and wire size.Early Catalinas had a safety upgrade to a new wiring harness, but I don't know how Hunters are wired.You can do a Forum Archive search on 'wiring harness' and find out more in detail without repeating it all here.Good luck,Stu
