I own a Hunter 386 (2004 model) which has the B&R rig and in-mast main furling. As everything in sailing is a compromise, there are pluses and minus. With the furling main, you lose sail area where it's most important - high up. The furling system doesn't work with sail havng any roach in them. Remember it has to roll up -even and smooth. On the other hand, setting the sail is a little easier (compromise) by having only to use the outhaul and a little effort toward the end with the aid of a winch. It's very easy to reef and can be done quickly. In my opinion, it's the type of sailing you enjoy that drives whether you want to hoist the main (and go just a little faster) or roll it out and enjoy the scenery. My biggest complaint with the B&R rig is the way Hunter designed the position of the jib sheets. On the 386 they run between the shrouds, which limits the size of your genoa to about 110% at best. So you have an easily sailing boat that can reach to 6 or 7 knots on a good day. The larger sails would be fun though in less then good conditions (low wind speeds). Just remember your designed hull speed is also a factor to consider.
