Hunter 386 : Need to replace striping on hull.
Sep 5, 2019
39
Hunter 386 Rock Hall
I’m thinking it may be the medium silver metallic. It seems to be very close to a faded black metallic. I hate to buy 150 ft just to see it’s the wrong color when I get it up there. It does come in 7/8 inch which is a hard size to find. I only need about 2 ft in length.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Ditto Waltsailor................medium silver metallic is the same color on my 2004 Hunter 386. Recommend getting a couple of samples first before you purchase. If you cannot get a sample then remove a small section and send it to the supplier for a match. I ended up purchasing a 150 ft roll for my Hunter 386 but then I replaced the stripping on both sides. Did the same on my Hunter 46.
39
I’m going to order the medium silver metallic. I took a couple photos but I don’t think they help. I will have enough stripe so that if it’s wrong, I’ll do the entire boat.
Likes: sail sfbay
