A
Andre
I chartered a 2005 Hunter 38 for a four day trip to catalina island.We left Marina Del Rey for Catalina Island and the trip over did not have good winds so we motored most of the way.On the return trip we had 20-23 knot winds and I thought we would have a great sail back to MDR. I started out with about 75% of the main and about 85% of the jib and the boat was overpowered so I rolled up the main to about 50% and left the jib as was and the boat felt balanced. I had a little weather helm in the gusts but felt ok with it, We had great sailing for about 45 minutes then I lost steering.Wow,I can't tell you how that felt, anyways the boat rounded up and I rolled up the jib and installed the emergency tiller and got the boat under control and removed the access cover to the steering assembly. After removing the cover I found the problem immediatly it was a bolt that connected a push pull rod from the wheel to the rudder post. Now it seems to me that this bolt about 3/4" in diameter is totally insufficient to handle the loads that a rudder can apply to this part.Now I know that when the gusts came I was applying rudder to conteract the tendancy of the boat to round up, thus the tremendous load on the steering system , but It should handle this no problem right?
