Hunter 376 plastic sail slides
Mar 26, 2015
109
Hunter 376 Marina del Rey
Greetings all,
I have a 1997 Hunter 376. I purchased her in July of 2014 and renamed and documented her as Mer-Sea Beaucoup (my wife's very good name choice).
Anyway, one of the plastic sail slides broke and I haven't been able to find a duplicate. The problem is the narrow neck required for the channel in the mast extrusion.
I took the pieces to West Marine (about half a mile from our condo) and found nothing comparable. All had wider and shorter necks (for lack of the correct term).
Who made them and what is the part number or replacement number.
Thank you.
Fair Winds,
Diablito
Dec 2, 1999
15,184
Check with Bainbridge International. Replace the nylon with a metal slug.
Mar 26, 2015
109
Woodster
Thank you. I didn't consider a sail loft as a retailer of anything as small as track slides.
Cheers!
Dec 18, 2012
168
Hunter 37.5 Annapolis
Also take a look at sailrite.com, in the hardware section, slugs and slides.
Paul
Mar 26, 2015
109
Paul,
Thanks. I had hoped to find stock somewhere within a 25 mile radius of Marina del Rey. No luck
The Selden mast requires an uncommon slide.
I found both the nylon and stainless at Bainbridge International and at Sailrite.com, but I had visions of replacing it this weekend. Didn't happen so, hopefully at Bainbridge's "stockist" in Huntington Beach or online.
Thanks again.
Tim
Mar 26, 2015
109
Thanks to all. Mare Co. (Mare Sails) sells retail.
I'm opting for stainless and should have them before this weekend.
Best to all of you.
Tim (Diablito)
