Hunter 356 windlass
Jan 17, 2023
4
hunter 38 fort Lauderdale
Hi everyone, I’m looking to buy a hunter 356 (exciting!) and it doesn’t have a windlass. The current owner just upgraded to a 45lb anchor and I love having oversized gear but want to fit a windlass.
Anyone got experience fitting a windlass to the 356? I’d imagine a horizontal Lewmar windlass like the RX2+ would do the job but thought I’d ask.
thanks!
Jan 4, 2006
7,380
First thing we require are pictures of your anchor locker to see what windlass will fit in it.
I installed a Lewmar V-1 in my '99 H-310 and I suspect the anchor lockers are similar, perhaps with yours being a little bigger. The installation of a windlass in a Hunter is seamless as there's no corrosion on the drive motor. I've seen a few other windlasses where the motor is installed within the anchor locker and they're a basketball sized ball of rust. Hard to see how they still operate.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
I put V3 on my 410. You might want a V2 with a 45# anchor. Contact Lewmar.
Mar 20, 2004
1,749
lewmar should be able to tell you the correct model = the 356 needs a special low profile model.
the original model used was from Simpson-lawrence (now lewmar), model 0045700 with gypsy and drum or gypsy only model 0045800. installation is fairly straightforward on the shelf at the back of the anchor locker; you cut out the circular molded spot in the locker cover to clear the drum.
You'll love the 356! We've owned Escape for 20 years now
