making a 356 "go"
Hi Deac,We have in mast furling too-more later. I found the most important things were paying attention to sail shape and trim, and keeping her upright and moving-the hull shape seems to perform best with no more than 10-15 degrees of heel, and the shoal keel depends on hydrodynamics (read water flow) to work-you need to keep her moving, even if you need to foot a little. We use the traveller, vang, halyard and outhaul to optimize the main, but I miss that large roach! We fly a Doyle APC with an ATN sock, with dual sheets. We replaced the standard short guy with a long guy that goes to a turning block on the anchor roller, then down the port side thru a set of furling blocks back to the cockpit. That way, we can control the chute luff tension for better control.After a year of trying to get the standard UK sails to work reasonably, we ordered a Doyle swingbatten main-we're still on the hard, but the new sail looks great and adds back the roach-sail area is increased about 30%, and the battens will kill the shaking leech we've been fighting! While Doyle was on board measuring, we discovered that Hunter and UK had short-changed us by about a foot of hoist on the jib! We ordered a new jib too, and not only added in the hoist but increased the overlap to 120%-as far as you can go with the current sheet tracks and the 356 stays. These changes should substantially improve her light air performance without compromising easy reefing. Doyle (Marblehead) really went the extra mile to solve my issues with the stock rig, and spent a lot of time learning my needs and thoughts and engineering a fairly complicated sail (the jib has a hollow leech with a complex shape to clear the stays). I would recommend them without hesitation. (Rationalize- the UK sails seem to die after about 2 years - I'll sail the Doyles, and when/if I sell her I have a new set of UKs in storage for the new owner.
