I am a new Hunter owner and am having problems with constant battery discharge. I can find nothing in the owners manual about how to set up the electrical system if the boat is not going to be used for over a week. Should I leave the AC Shore Power connected and on--will that charge the battery while the boat is not in use? Any suggestions would be appreciated.
Thanks,
Ryan
Ryan: WELCOME!
Yes leave the shore power plugged in and turned on. Make sure that the battery charger is in the on position on the electric panel.
On my boat I leave the 12 volt fridge on, the freezer on. That is it. I need cold beer and frozen pizzas.
On the 120 volt side it is the charger that is on. Everything else is off. If you have AC, you might want to leave one of the two units on, once it warms up, in the AWAY mode so that it dehumidifies your boat.
This should keep everything fine.
Have fun!
