Hunter 340 refrigerator
HD74
Dec 27, 2016
64
Hunter 340 Pickwick tn
I need to add some insulation around the outside of my refrigerator on my 1999 hunter 340. is anyone familiar with what I must do. Thanks so much for any and all help
JamesG161
Feb 14, 2014
7,817
Hunter 430 Waveland, MS
What is your refrigerator model number?
On my H430 is much bigger size.
but...
I used non - expanding foam on mine.
Jim...
Jun 17, 2022
278
Hunter 380 Comox BC
Do you have access all around the refrigerator??? You can use foam insulation. It has to taped everywhere, otherwise it's ineffective as an insulator. Therefore, access is critical. That being said, even if you can only access one side properly, it should make a small difference. One inch pink foam is about R5, which would likely double your insulation.
  • Helpful
