Hello,
What is the procedure for tensioning the fore stay on a Hunter 340 with a B & R rig?
Decided to leave the mast up this winter and observed the fore stay (which has roller furling) seems a bit slack. A bit slack is a subjective initial observation in absence of putting a tension meter on it. (This will be done)
So, lacking a back stay how does one go about increasing then tension on the fore stay? Are the lower turn buckles connected to the upper shrouds the place to start for the initial adjustment and is there a documented procedure for mast bend that a fellow sailor would care to share? (It wasn't part of the Hunter manual that came with the boat).
Thanks,
Bob
Thanks,
Bob
