Hunter 34 Windlass possibilities?
6
Hunter 34 Shelburne
I currently own a 1986 Hunter 34 and I want to install a windlass. As you may know it has a shallow anchor locker. I am not interested in glassing over the anchor locker since there is no good below deck access. Can anyone recommend a model that will work within the confines of the space available. And can anyone give some good advice as to how to do this installation successfully.
Thank you,
Jessie Fender
Oct 14, 2005
2,191
Jessie...
search through the H34 owner's modification forum for Fred Ficarra's H34 "Epitome" renovations. I believe he installed a windlass in his anchor compartment. There may be other similar projects in the H31 files as well.
Sep 21, 2009
385
Hunter 34 Comox
I installed one on mine. I cut the anchor locker lid just in front of the latch. I then strengthened the 2 peices from the bottom by glassing them to full thickness with heavy cloth. I had to remove the balsa coring but that was an easy job. The front half of the hatch is now fixed in place and the back still opens for access. I used a Lewmar V700 pro because of its small size and low profile. I do have to sit there and rake the rode and chain out of the way as I haul anchor but it works very well. I carry 100ft of chain and 150ft of rode.
Dec 28, 2010
6
Hunter 34 Shelburne
Thanks very much for the suggestion!
