Hi;
My Maxwell winches are nearing end of life; I have rebuilt - lubricated- then last summer and I saw warn teeth and bad lubrication.
Any suggestions on size?
I would like to go to self tailing two speeds on the cabin top ( are through-bolted) perhaps slightly larger.
Are the rear winches through-bolted - if so how do you get at them with out turning into a pretzel? If there is an embedded deck plate does it need to be re-drilled and tapped?
Thanks in advance. Ilan
