I sail a 1984 Hunter 34. Primary winches are Maxwell 24 st with base diameter of 6". I was given a pair of Lewmar 46 st with a base diameter of 7". In order to make them work I would have to remove large cleat on top of coaming and move winch location toward the cabin as the coaming widens as you move forward. Is there anything I need to consider when repositioning the winch location? Thank you, Randy
