Also, be really careful with the wiring as it is probably all spliced and taped together. You will have to lift the mast just slightly, pull the harness's out and seperate them carefully. When I re installed mine I cut a hole and installed an inspection plate near the bottom so that I could get at the wiring without having to pull the mast. Rig Rite has these covers as welll. Cheers.
