No Compression Post Problem on My 1983 h34
After all of the talk about the compression post problem, I took the teak off of the compression post so that I could inspect it, top to bottom. That meant drilling out all of the teak plugs, and removing the screws. My original compression post is fine, no rot, no water leaks, no damage. I put the teak back and left it alone.However, I don't disagree that this is a potentially problem area. I think that it was not a serious problem on the early 1983 boats, such as mine. I have a large, black metal plate, upon which the mast is seated, on the cabin top. From my reading of other posts, this plate was discontinued in late 1983 or early 1984. I think that plate, offered some additional protection for the potential water seepage ad resultant damage, that does appear to be a chronic problem on the h34's. Or, maybe I was just born under the right stars!on.
