There is a solution to overheating 3YM30
David, Your dealer should have notified you by now that, there is and has (for a while) been an overheating problem caused by using 'bad' coolant. This results in a subsequent problem with the heat exchanger on some 3YM20/30 engines. My boat is a 2004 Hunter 33(hull 166) and the overheating problems began after only 20 hours engine-time. It is now up to 70 hours. The dealer in Toronto was not and has not been helpful. Throughout last summer the problem continued intermittently but as has been said on this and other forums, the overheating alarm usually goes off at RPMs anywhere between 2400 and up. With my engine, after 10 mins at 2600 RPM it was sure to go off, so I kept below that level. That is, until a few weeks ago. I got caught in roughish weather in a busy part of the Thousand Islands and really needed that engine - but you guessed it, the overheating alarm kept sounding. In that instance at around 2400 RPMs. I had to let the engine cool off for a while then restart. After about an hour of careful throttle management I managed to keep the engine alarm quiet at 1800 RPM. At the time I was slamming into a heavy swell with the wind on my nose gusting to 30 kts I could only manage about 2 kts boatspeed. Sails were not much of an option because of shoals and having to navigate through a narrow passage. The next day I call the Yanmar rep in Toronto and was informed that Yanmar is currently rectifying the problem on all the engines that have reported overheating. My turn came last Friday. I see from this forum Hunter blames Yanmar but then Hunter always blames someone else. Yanmar says the problem is with Hunter. The Yanmar reptold me Yanmar ships all its engines in crates "dry" to Hunter, who then adds coolant to the engines. Unfortunately, 100% coolant was added to a fair number of these engines. The Yanmar guy said the mixture should have been a 50/50 mix. Of course the 100% coolant boils at a lower temperature. To make matters worse, the boiling coolant leaves a residue in the heat exchanger which builds up and inhibits the water flow and in turn the cooling efficiency of the system. The Yanmar rep flushed out my entire cooling system and removed and replaced the heat exchanger. He refilled the system with clean 50/50 mix of pink (Texaco long life??)coolant starting at the heater (through its hoses then reconnected them). He then slowly filled the rest of the system (by the way the green coolant is verboten) taking care to avoid creating airlocks. The engine was run for about 20 minutes at idle then we went out for a test run.Through an hour of high RPM use the engine performed flawlessly. We got it up to 3600 RPM and kept it there for quite a while and the hottest temperature (he used some type of electronic gizmo to measure the temperature) the engine only got up to 83 deg C while at 3600 RPM for several minutes. I am told that the alarm goes off at 95 deg C and stops at 93 deg C. However the rep said on some engines it could sound as low as 93 deg C and stop at 91 deg C. He showed me that at 3200 RPM the engine temp remained at 73 deg C.I am finally convinced that the overheating problem is solved on my 3YM30. My next project is to fit a temperature gauge and retain my alarm system (belts and braces). Yanmar is not enthusiastic about helping with a solution but suggests the additional sender probe should go out of the water-heater engine outlet.If you want your overheating problem to go away by-pass Port Credit and call Danny at Total Power in Mississauga.
