I'm chasing down a slow leak on my 2006 Hunter 33 which seems to be originating midship port side. I want to check my lower genoa track to see if that is where the rainwater is getting in from but can't find much information on removing it. I believe it is bolted into place but there is no easy access on the inside. I have read somewhere that the bolts fasten to a steel backer embedded into the deck which has threaded holes to receive the bolts but I can't confirm this.
Has anyone on this forum removed and reset their genoa tracks on a 33 hunter and if so can you confirm that the access is all via the deck?
thanks in advance
thanks in advance
