hunter 33 2004 bar indicator
I’m not new here so I’m guessing I’m not the only one with this question - What does a bar indicator indicate?
May 1, 2011
4,363
Pearson 37 Lusby MD
If you don't already have one, you need to get a Raymarine Rudder Reference Indicator to show rudder angle on the control head for your autopilot.
May 7, 2012
1,389
Hunter e33 Maple Bay, BC
@michel06440 I believe this what you want to install.
My Hunter 33 is a 2012. So it is not exactly the same set up as yours. I could not find enough room for the rudder position sensor (rudder angle indicator???) in the quadrant well.
So I added a piece of aluminum stock on two simple “L” brackets and mounted the sensor upside down on that.
Here is the rudder position sensor in the inverted location. I hope this helps.
  • Helpful
