Hunter 320 holding tank
Dec 2, 1997
9,007
- - LIttle Rock
Hi Will...welcome to sbo.com!
'Twould be helpful to know the year of the boat. If it's pre-1990s, it may be aluminum...mid'90s is when Hunter switched to plastic. DuraCast ( now known as DuraWeld DURAWELD ) was the tank mfr. If you can give them the year and model, they should be able to ID the tank.
--Peggie
  • Helpful
2
Hunter 320 Deale, MD
Thank you Peggy. I have contacted Duraweld and I'm waiting for their response. BTW, it is a 2021 Hunter 320 and the tank is plastic. The original volume level sensor is not functioning any longer and I am replacing it with a non-contact design and I need the height of the tank to order the correct sensor strip.
Thanks again,
Bill
