2GM20F
I believe the 2GM20F is the same engine on the 28.5; the 290 and perhaps the 320. Their respective displacements are 7,000/7,100# for the 28.5; 7,400# for the 290; and 8550# for the 320. Presumably the underbody on the wider 320 has more drag as well. While I've never had any problem in any wind and wave conditions with my 28.5; I'd guess that a 20% higher displacement (over the 28.5), wider beam, and winged keel should need more power to reach hull speed. I'd question if the combination is adequate on the 320 even with a three blade prop.
