stepping / unstepping
I had the mast unstepped in South Carolina and had the boat trucked to NY last July. There weren't any major obstacles except that I missed the best part of the Marina crane getting the mast in .... I live about 3 miles from the marina and ran home for 20 minutes, and in the interim, the marina crew went ahead with the crane work due to an approaching electrical storm ... by the time I got back, all I had to do was insert the 18" (approximate) bolt through the base and bottom of the mast and put the nut on. and then hook up the electric and plug in the antenna.
Actually- had one hitch ... the marina crew left the forestay as it arrived by truck ... no one eased the rigging to create some slack ... I backed off on the bottom turnbuckle as much as possible but still needed two people struggling to put down-pressure on the forestay so I could get it attached to the furler base.
I guess I need to connect with some canal travellers to find out about the overhang. You West coast guys don't need to worry about canals!
Any guesses as to the effect on the center of gravity effects if I put the total weight of the mast horizontally above the cabin?
