I have a 2000 Hunter 310, The water heater is rusting a the bottom. I am going to replace it, but it looks like it is hard to remove without removing the pump and other plumbing. Has anyone done this and how did you go about removing it.
.................... in that the jacket on my Seaward water heater is SS. The heat exchanger is aluminum tubing. Any chance you're looking at something other than corrosion staining at the bottom. Or maybe it's just that heaters are really getting cheap.The water heater is rusting a the bottom.
They make covers galvanized, aluminum and stainless. Same heater core. This one could be galvanized..................... in that the jacket on my Seaward water heater is SS. The heat exchanger is aluminum tubing. Any chance you're looking at something other than corrosion staining at the bottom. Or maybe it's just that heaters are really getting cheap.
