Hunter 310 mast
Peter de Bruin
Last year, I have bought a second hand 1997 Hunter 310. The mast has a sign with the following : Ste Z Diffusion - South East Inc. - 6320 NW 123 RD Place - 32606 Gainsville - Phone 904 462 5146. However the operator tells me that this phone-number is not complete. Also I have searched for Ste Z Diffusion on the internet but could not find a mast manufacturer with that name. As the current mast has corrosion and needs to be replaced I am looking for the manufacturer. For your information ; it is a typical mast. It is supported with two booms from the deck attached at the bottom level of the main sail boom. Also the whole construction looks like a triangle with no support at the back of the boat. The label on the spar mentions also Type: H310 and Reference : 4.13 - 97JC I think as it is not clear to read at all Does anybody know the name of the manufacturer or any other relevant detail? Thanks,Peter
W
Wayne Estabrooks
Z-Spars - US Spars
Peter, Not sure if I have all my facts correct but Z-Spars, now called US Spars in the US and still Z-Spars in the UK. Do a Google search for Z-Spars. The address and phone number is below. Perhaps someone has better info. I'm sure Hunter could probably help also. Z-Spars used to make masts for the Hunter boats up until sometime in 1997 or 1998. My '97 Hunter 340 has a Z-Spar mast. Good luck. Also ther is a Z-Spars in the UK The US office is as follows. US Spars Inc. 6320 NW 123rd Place Gainesville, FL 32653 Telephone 386-462-3760 386-462-3448 fax info@usspars.com
C
Clayton
US source for all things Z-Spar
Rig-Rite, Inc. carries all of the Z-Spar mast sections and fittings. They are at www.rigrite.com. They recently had a major fire and are operating in a limited fashion. I did order and receive a mast base turning block a few weeks ago so I hope that is a good omen.
Jun 7, 2004
31
Hunter 310 Herrington Harbour South, MD
Try these web sites
Try these three sites. One in UK, one in France and one in US. Good luck. Lee S/V Calaloo http://www.zsparsuk.com/ http://www.z-spars.com/ http://www.usspars.com/corporateinformation.html
Peter de Bruin
Found the answer
Thank you all for your replies and help. I have found Z-Spars in the UK and France. Meanwhile my mast has been taken from the boat and needs to be replaced by a new one due to incorrect installation by the previous owner. To me this means a very expensive excersise. The good news is that all components can be used - a one days work, I am told to fit them on the new mast, if we could find the original supplier But with your information this looks very promissing. Hopefully they have the original or a equally good or better replacement.. I will keep you posted on any developments - regards Peter
