Thanks to both replies .. I should have mentioned that the boat is on a lake in South Texas and we mostly only use the AC in the evening and at night when we spend the night.. Don't have a generator so connected to shore power anytime we use the AC. It definitely gets hot here in the summer months, not uncommon for 100 degrees days. The old unit would take a 2-3 hours in the evening to get it down to a decent temp (going from about 95 to hi-mid 70s) and as long as we keep the companion way covered. And at night could keep it at low 70s without much issue. That said, we might not attempt to spend the night if it's going to be brutal hot
There is an 11K BTU MarinAire unit that might just fit .. i would prefer to go a little higher than a little lower .. but as you guys mentioned, may not make much of a difference .. We will also be getting new hatch covers and better interior shades to cut down on sunlight/heat .. my bimini is fairly large so it covers the main berth, companion way, galley and head area fairly well in the evening ... will likely pull out the old unit this weekend and get some exact dimensions so i can be more certain of what will fit and what will not ..
Thanks again !!
