Hunter 31 window/cabin roof leak
Roger Moore
I am taking on rainwater from the port side's aftmost rectangular window. The water is dripping through the inside on the aft part of the window, and doesn't appear to be a leak from the window itself. I am about to replace the clunky window frames for these, but I was wondering if it might be the holes drilled for the screws that hold the old frame in, or if anybody had tracked such a leak to a different source/mast boot/hatchway drain, or some other seam.
John
I'm still dealing with the same problem
Roger, I have the same problem and raised it on this forum last fall. The link to the archives is below and it's relevant because I did get some good replies that you may want to read. I tried rebedding and calking a number of places but still haven't resolved the problem. Now that the Florida rainy season is getting underway, it's important to get this fixed. Here is some advice that I picked up elsewhere and I plan to try it soon myself. ---------------------------------------- Get the following: a powerful leaf blower, a piece of plywood the size of your companionway hatch opening with a hole cut in the middle the size of the blower outlet tube, tape, a bottle of dawn and a gallon bucket. ( On the H31, I think you only need replace one hatchboard with the plywood ) Place the plywood in companion way, close the top hatch slider, and tape the slider edges and plywood edges as air tight as possible. You wont be able to make them completely air tight, but do your best. Tape up hatches in similar manner and insert the blower into the plywood hole. Mix a pretty concetrated solution of water and dish soap. Turn the blower on and get the inside of the cabin pressurized. ( The stronger the blower, the better.) Now walk around your deck and dab small amounts of the soapy water solution around all deck hardware. The leaking culprit(s) will have bubbles around them while the non-leakers will have nothing. Bubbles will slowly form, so don't expect to see a froth. This advice further stated that when you do find the leak, use a polysulfide sealant in order to facilitate removal in the future. I'm not going to argue that point. Use whatever sealant you feel is best. John
