Hunter 31 Merriman Pedestal Guard
3
Hunter 31_83-87 Gilford, NH.
Can anyone tell me if the Edson 9-1/2" wide pedestal guard will work on the original Merriman 1984 pedestal. It just seems as though the pedestal base is to wide. If it won't what will and where can I get one. Thank You _/) _/)
Dec 2, 1999
15,184
Screw the binical into the pedestal
Chet: I have the same setup on our H'31. When the boat was delivered they made the binical with curved legs. The legs DO NOT bolt into the cockpit sole, but into the pedestal. This solves two problems. First you do not need to worry about water leaking into the cockpit sole (no holes to cause a leak), the other thing is that you do not stub your toes on the binical posts. I will try to remember to get some photos of this setup the next time I am down.
