Don't know if you can use that measurement
Bill:I do not know if you can use that measurement. Your boat (same as mine) has pre-bend in the mast. According to the manual the desired mast pre-bend is 1% of the mast height above the boom (.01 x mast height above the boom). On a 50' mast this would be .5' (6") at the mid point of the mast. The H'31 would be more like 3.5" to 4" (I don't have the measurements).Once this has been determined, the mast need to be vertical or slightly raked aft. The more rake the more weather helm.
