NUMBER OF "RINGS"
Jerry: The info Steve gave you is right on. You didn't specify what model Hunter you own, so any of those are possibles depending on your shaft diameter. There are a number of materials available for packing, including wax, teflon (my choice) and some other more exiotic stuff. Check with your local marine store. As for the number of rings to use, there is no set number. Most people I know say they use 3 rings of packing with the ends spaced so they don't align when in place. I'd recommend you use whatever number you remove. On my H31, believe it or not, I was never able to get more than 1 ring of packing in! Seemed to work fine though so I just left that number alone and changed the packing at every haulout. Good luck!Tim Leighton
